Inleiding
Prereq for disconnecting the battery of your Samsung Galaxy A10e.
Wat je nodig hebt
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
Remove screws from the motherboard antenna cover.
3 Phillips #00, 3mm length.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
7 andere personen hebben deze handleiding voltooid.
