Inleiding
The screen on basis peak is essential to the functionality of this device. The screen displays all of the features available in the device. The screen of the Basis Peak can be replaced if there are any issues with the device's display by following this guide. The disassemble should not be a problem for there is only one way to remove the screen.
Wat je nodig hebt
Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
Flip over the motherboard complex and gently remove the screen with your fingers.
