Ga door naar hoofdinhoud
Backyard Fence Post Replacement
Wat je nodig hebt
    1. Backyard Fence Post Replacement, Backyard fence post: stap 1, afbeelding 1 van 2 Backyard Fence Post Replacement, Backyard fence post: stap 1, afbeelding 2 van 2
      • Measure the damaged post to purchase the replacement.
      • Take photo of post and take note of where the boards are connected.
      • Clear out work area of any clutter or hazards.
      Vraag FixBot
      Voeg opmerking toe
    2. Backyard Fence Post Replacement: stap 2, afbeelding 1 van 1
      • Use a shovel to dig a deep hole around the post until you expose the concrete below the soil.
      • If necessary you can attempt to break off the top of the post to allow for more room. The pickaxe can be a good tool for this.
      • Make sure to keep the excess dirt in a small pile, as this is what you need to fill the hole.
      Vraag FixBot
      Voeg opmerking toe
    3. Backyard Fence Post Replacement: stap 3, afbeelding 1 van 1
      • Excavate the dirt surrounding the concrete to allow more room for the pickaxe.
      • Use a pickaxe to break up the concrete into smaller chunks and remove them from the hole.
      Vraag FixBot
      Voeg opmerking toe
    4. Backyard Fence Post Replacement: stap 4, afbeelding 1 van 1
      • Carefully lift the post out of the hole.
      • Leave the hole as it is, so you don't have to do additional digging.
      Vraag FixBot
      Voeg opmerking toe
    5. Backyard Fence Post Replacement: stap 5, afbeelding 1 van 1
      • Insert the new post into the hole left by the damaged one.
      • If the post is loose, place the larger concrete chunks to support the post while you prepare for the next step.
      Vraag FixBot
      Voeg opmerking toe
    6. Backyard Fence Post Replacement: stap 6, afbeelding 1 van 1
      • Fill in the hole about halfway around the post, leaving 6-10 inches below the surface to allow room for the concrete.
      Vraag FixBot
      Voeg opmerking toe
    7. Backyard Fence Post Replacement: stap 7, afbeelding 1 van 2 Backyard Fence Post Replacement: stap 7, afbeelding 2 van 2
      • Use the drill and screws to secure the fence support beams to the new fence posts.
      • Use 2-3 screws per support to ensure that the fence remains sturdy.
      Vraag FixBot
      Voeg opmerking toe
    8. Backyard Fence Post Replacement: stap 8, afbeelding 1 van 1
      • Pour 3-4 inches of cement into the hole surrounding the new post.
      • Following the directions on the cement, pour room temperature water over the powder until it is fully saturated and some water remains on top.
      • Wait 2-3 hours for cement to set.
      Vraag FixBot
      Voeg opmerking toe
    9. Backyard Fence Post Replacement: stap 9, afbeelding 1 van 1
      • Cover the cement with the remaining dirt once it has finished setting and pat it down.
      Vraag FixBot
      Voeg opmerking toe
    10. Backyard Fence Post Replacement: stap 10, afbeelding 1 van 2 Backyard Fence Post Replacement: stap 10, afbeelding 2 van 2
      • Line up boards with existing boards so they are flush with the ground.
      • Use the drill and screws to secure the boards to the the post.
      • Use 2 screws at both the top and bottom of the boards to distribute weight.
      • Clean up the work area and check for lost screws.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
By the end of this guide the post should be installed and secure.
kaitlyn
189 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 40
Altijd: 392
