Inleiding
In this guide it teaches how to remove the back panel of the laptop. You will need a screwdriver and a opening tool to complete this task.
Wat je nodig hebt
Flip the laptop so that the back is facing upwards.
Locate the small screw on the back that holds the "L" shaped panel.
Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
