Inleiding
This guide will teach you how to open up a BaByliss i-Pro 45 to change its batteries.
3x AAA 1.2V batteries with U-lips are required to be soldered onto the motherboard.
Opening up the device is an ideal opportunity to thoroughly clean it. Under the head/blades, some hairs may be stuck.
Wat je nodig hebt
Remove the rubber plug hiding the screw
Remove the screw under the plug
Remove two screws below the blades with a long Philips screwdriver
Remove the screws at the bottom of the blade
Remove the blade
open the plastic parts holding the circuit in place
start lifting from the tail
14 andere personen hebben deze handleiding voltooid.
14 opmerkingen
Personally, I have been using this hair clipper for many years and it works perfectly well. Today I have to replace the battery. Can anyone tell me what the battery model is and if I need to use a soldering iron to replace it?
It is mentioned above:
So yes, a soldering iron is required, and the battery must have lips (i.e. not the standard AAA batteries you can find in any shop).
Fuss -
