Ga door naar hoofdinhoud
BaByliss i-Pro 45 shaver battery Replacement
Wat je nodig hebt
  1. BaByliss i-Pro 45 shaver battery Replacement, Remove the screws of the housing: stap 1, afbeelding 1 van 1
    • Remove the rubber plug hiding the screw
    • Remove the screw under the plug
    • Remove two screws below the blades with a long Philips screwdriver
  2. BaByliss i-Pro 45 shaver battery Replacement, Remove the blade (Optional): stap 2, afbeelding 1 van 2 BaByliss i-Pro 45 shaver battery Replacement, Remove the blade (Optional): stap 2, afbeelding 2 van 2
    • Remove the screws at the bottom of the blade
    • Remove the blade
  3. BaByliss i-Pro 45 shaver battery Replacement, Open the housing: stap 3, afbeelding 1 van 3 BaByliss i-Pro 45 shaver battery Replacement, Open the housing: stap 3, afbeelding 2 van 3 BaByliss i-Pro 45 shaver battery Replacement, Open the housing: stap 3, afbeelding 3 van 3
    • Gently open the housing
  4. BaByliss i-Pro 45 shaver battery Replacement, Lift the circuit: stap 4, afbeelding 1 van 2 BaByliss i-Pro 45 shaver battery Replacement, Lift the circuit: stap 4, afbeelding 2 van 2
    • open the plastic parts holding the circuit in place
    • start lifting from the tail
Conclusie
14 andere personen hebben deze handleiding voltooid.
Stanky
1.268 Reputatie
6 handleidingen geschreven
14 opmerkingen
@fuss did you succeed?
Stanky - Antwoord
I haven’t bought the batteries yet. They were overpriced in my region (with shipping costs). For now, I use the shaver with leads connected.
Fuss -
Use low self-discharge NiMHs and it will make you angry many years.
Design of this cutter is faulty - it tugs your hair when you try to cut too much or too fast.
Leszek J - Antwoord
Personally, I have been using this hair clipper for many years and it works perfectly well. Today I have to replace the battery. Can anyone tell me what the battery model is and if I need to use a soldering iron to replace it?
JulienCharb - Antwoord
It is mentioned above:
3x AAA 1.2V batteries with U-lips are required to be soldered onto the motherboard.
So yes, a soldering iron is required, and the battery must have lips (i.e. not the standard AAA batteries you can find in any shop).
Fuss -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 23
Afgelopen 7 dagen: 122
Afgelopen 30 dagen: 508
Altijd: 18,015
