Ga door naar hoofdinhoud
BRCK v1 Modem Replacement
Wat je nodig hebt
    1. BRCK v1 Modem  Replacement, Top Cover: stap 1, afbeelding 1 van 1
      • Place the face of the device showing BRCK face up.
      Vraag FixBot
      Voeg opmerking toe
    2. BRCK v1 Modem  Replacement: stap 2, afbeelding 1 van 1
      • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. BRCK v1 Modem  Replacement: stap 3, afbeelding 1 van 1
      • Remove the top cover.
      Vraag FixBot
      Voeg opmerking toe
    1. BRCK v1 Modem  Replacement, Modem: stap 4, afbeelding 1 van 1
      • Cut the black zip tie holding the modem down.
      • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
      Vraag FixBot
      Voeg opmerking toe
    2. BRCK v1 Modem  Replacement: stap 5, afbeelding 1 van 1
      • Remove the connection located on the edge of the modem.
      Vraag FixBot
      Voeg opmerking toe
    3. BRCK v1 Modem  Replacement: stap 6, afbeelding 1 van 2 BRCK v1 Modem  Replacement: stap 6, afbeelding 2 van 2
      • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
      Vraag FixBot
      Voeg opmerking toe
    4. BRCK v1 Modem  Replacement: stap 7, afbeelding 1 van 3 BRCK v1 Modem  Replacement: stap 7, afbeelding 2 van 3 BRCK v1 Modem  Replacement: stap 7, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
      • Lower the plate and gently pull the ribbon out of the face plate.
      • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
      Vraag FixBot
      Voeg opmerking toe
    5. BRCK v1 Modem  Replacement: stap 8, afbeelding 1 van 2 BRCK v1 Modem  Replacement: stap 8, afbeelding 2 van 2
      • Remove the modem from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jeret Buerger
501 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-3, Lancaster Spring 2015 Lid van Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Leden
28 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 504
