Ga door naar hoofdinhoud
BRAUN Cruzer 5 - Battery Replacement
Wat je nodig hebt
  1. BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: stap 1, afbeelding 1 van 3 BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: stap 1, afbeelding 2 van 3 BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: stap 1, afbeelding 3 van 3
    • Remove the trimmer head.
    • Remove the two Torx T5 screws attaching the cover to the hand-piece.
    • Remove the cover.
    • Take this opportunity to remove built up hair and residue. Hair can prevent the batteries from making contact leading to power failure.
  2. BRAUN Cruzer 5 - Battery Replacement, Back cover removal: stap 2, afbeelding 1 van 3 BRAUN Cruzer 5 - Battery Replacement, Back cover removal: stap 2, afbeelding 2 van 3 BRAUN Cruzer 5 - Battery Replacement, Back cover removal: stap 2, afbeelding 3 van 3
    • Remove the back cover.
    • Using a flat head screw driver, remove the single screw holding the power board in place.
    • Use compressed air to clean the motor. Lubricate the trimmer with a suitable lubricant.
    • Remove the two AAA batteries by de-soldering them with a soldering iron and de-soldering pump.
    • Bend the terminals of the new batteries and solder them back in the right direction
    • If the batteries are already slightly charged, you can briefly press the power button to check if the motor is working
    • Insert the board again, with the side towards the motor first
  3. BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: stap 3, afbeelding 1 van 3 BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: stap 3, afbeelding 2 van 3 BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: stap 3, afbeelding 3 van 3
    • Remove the front cover of the device.
    • Clean and lubricate this area thoroughly as well, then your device will run better.
Conclusie
24 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Zweikeks
599 Reputatie
2 handleidingen geschreven
7Gids Commentaar
Your guide saved me from purchasing a new device.
After replacing the batteries it works again like a charm!
King Arthur - Antwoord
Thanks this was helpful. The Braun Series 3 Hair Clipper HC3050 has a VERY similar design. Some additional notes: After removing the screws, it takes a bit of force to get the back separated from the front. I had to gently pry it apart with a screw driver. The very inside is slightly different, but same concept.
Jaden Fox - Antwoord
Die Anleitung war sehr hilfreich.
Der Austausch der Batterien ging ziemlich gut.
Wilhelm Gregorius - Antwoord
I think one pcc— 1.2 V 1800 mah AA battary
Ünsal Şeker - Antwoord
Thank you! Another appliance reborn :)
It really helps to work around consumerism with such shared knowledge!
Keep it up 👍
Pedro Faria - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 252
Altijd: 31,230
