Ga door naar hoofdinhoud
BOSE SoundTouch 30 Subwoofer Replacement
Wat je nodig hebt
  1. BOSE SoundTouch 30 Subwoofer Replacement, Base Plate: stap 1, afbeelding 1 van 2 BOSE SoundTouch 30 Subwoofer Replacement, Base Plate: stap 1, afbeelding 2 van 2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
    Vraag FixBot
    Voeg opmerking toe
  2. BOSE SoundTouch 30 Subwoofer Replacement, Power Supply: stap 2, afbeelding 1 van 1
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
    Vraag FixBot
    Voeg opmerking toe
  3. BOSE SoundTouch 30 Subwoofer Replacement: stap 3, afbeelding 1 van 2 BOSE SoundTouch 30 Subwoofer Replacement: stap 3, afbeelding 2 van 2
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    Vraag FixBot
    Voeg opmerking toe
  4. BOSE SoundTouch 30 Subwoofer Replacement: stap 4, afbeelding 1 van 1
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
    Vraag FixBot
    Voeg opmerking toe
  5. BOSE SoundTouch 30 Subwoofer Replacement: stap 5, afbeelding 1 van 2 BOSE SoundTouch 30 Subwoofer Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
    Vraag FixBot
    Voeg opmerking toe
  6. BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: stap 6, afbeelding 1 van 3 BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: stap 6, afbeelding 2 van 3 BOSE SoundTouch 30 Subwoofer Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Remove the five 15.5 mm PH2 screws holding the motherboard down.
    • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
    • Remove the motherboard.
    • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
    Vraag FixBot
    Voeg opmerking toe
  7. BOSE SoundTouch 30 Subwoofer Replacement, Subwoofer: stap 7, afbeelding 1 van 1
    • Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
    • Remove the plastic insert.
    Vraag FixBot
    Voeg opmerking toe
  8. BOSE SoundTouch 30 Subwoofer Replacement: stap 8, afbeelding 1 van 1
    • Remove the three 15.5 mm PH2 screws holding the metal insert down.
    • Remove the metal insert.
    Vraag FixBot
    Voeg opmerking toe
  9. BOSE SoundTouch 30 Subwoofer Replacement: stap 9, afbeelding 1 van 1
    • Remove the three 19 mm PH2 screws holding the metal subwoofer cover down.
    • Remove the subwoofer cover.
    Vraag FixBot
    Voeg opmerking toe
  10. BOSE SoundTouch 30 Subwoofer Replacement: stap 10, afbeelding 1 van 1
    • Remove the four 19 mm PH2 screws holding the subwoofer in place.
    • Be careful not to let the screwdriver slip and damage the fragile subwoofer.
    Vraag FixBot
    Voeg opmerking toe
  11. BOSE SoundTouch 30 Subwoofer Replacement: stap 11, afbeelding 1 van 2 BOSE SoundTouch 30 Subwoofer Replacement: stap 11, afbeelding 2 van 2
    • Remove the subwoofer by pulling towards the back of the device while tucking the wire under the plastic enclosure.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Brennen Irey
1.269 Reputatie
6 handleidingen geschreven
Cal Poly, Team S16-G2, Livingston Spring 2018 Lid van Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 51
Altijd: 5,625
