Ga door naar hoofdinhoud
BOSE SoundTouch 30 Motherboard Replacement
Wat je nodig hebt
    1. BOSE SoundTouch 30 Motherboard Replacement, Base Plate: stap 1, afbeelding 1 van 2 BOSE SoundTouch 30 Motherboard Replacement, Base Plate: stap 1, afbeelding 2 van 2
      • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
      Vraag FixBot
      Voeg opmerking toe
    1. BOSE SoundTouch 30 Motherboard Replacement, Power Supply: stap 2, afbeelding 1 van 1
      • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
      Vraag FixBot
      Voeg opmerking toe
    2. BOSE SoundTouch 30 Motherboard Replacement: stap 3, afbeelding 1 van 2 BOSE SoundTouch 30 Motherboard Replacement: stap 3, afbeelding 2 van 2
      • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
      • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
      Vraag FixBot
      Voeg opmerking toe
    3. BOSE SoundTouch 30 Motherboard Replacement: stap 4, afbeelding 1 van 1
      • Remove all four 15.5 mm PH2 screws holding the power supply down.
      • The power supply is identified by a green board with a large metal covering.
      Vraag FixBot
      Voeg opmerking toe
    4. BOSE SoundTouch 30 Motherboard Replacement: stap 5, afbeelding 1 van 2 BOSE SoundTouch 30 Motherboard Replacement: stap 5, afbeelding 2 van 2
      • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
      • Pick up the power supply and remove the fourth cable from the underside of the power supply.
      • Remove the power supply.
      Vraag FixBot
      Voeg opmerking toe
    1. BOSE SoundTouch 30 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
      • Remove the five 15.5 mm PH2 screws holding the motherboard down.
      • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
      • Remove the motherboard.
      • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Brennen Irey
1.269 Reputatie
6 handleidingen geschreven
Cal Poly, Team S16-G2, Livingston Spring 2018 Lid van Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Leden
14 handleidingen geschreven
5Gids Commentaar
Where do I can get the power supply?
Ulises Peña - Antwoord Deel
where can i get the notherboard? 354437-0060
guillermo gibson - Antwoord Deel
Please where can I get the motherboard
Marjorie Newell - Antwoord Deel
Where can I get the motherboard?
Bryan Lozano - Antwoord Deel
I am getting an error “Error code 0000. Contact Bose service” what do I do?
Ashley Murray - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 71
Altijd: 7,679
