Ga door naar hoofdinhoud
BLU Life XL Rear Camera Replacement
Wat je nodig hebt
    1. BLU Life XL Rear Camera Replacement, Rear Camera: stap 1, afbeelding 1 van 3 BLU Life XL Rear Camera Replacement, Rear Camera: stap 1, afbeelding 2 van 3 BLU Life XL Rear Camera Replacement, Rear Camera: stap 1, afbeelding 3 van 3
      • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
      • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
      • Remove the battery by lifting the lower edge of the battery up first.
      Vraag FixBot
      Voeg opmerking toe
    2. BLU Life XL Rear Camera Replacement: stap 2, afbeelding 1 van 2 BLU Life XL Rear Camera Replacement: stap 2, afbeelding 2 van 2
      • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. BLU Life XL Rear Camera Replacement: stap 3, afbeelding 1 van 2 BLU Life XL Rear Camera Replacement: stap 3, afbeelding 2 van 2
      • Insert the plastic prying tool in between the plastic frame and the device.
      • Keep the phone on the surface with its screen down.
      Vraag FixBot
      Voeg opmerking toe
    4. BLU Life XL Rear Camera Replacement: stap 4, afbeelding 1 van 2 BLU Life XL Rear Camera Replacement: stap 4, afbeelding 2 van 2
      • Use the plastic prying tool to gently push the rear camera out from its socket.
      • Take the camera out and set it aside.
      Vraag FixBot
      Voeg opmerking toe
    5. BLU Life XL Rear Camera Replacement: stap 5, afbeelding 1 van 2 BLU Life XL Rear Camera Replacement: stap 5, afbeelding 2 van 2
      • Carefully place the new camera in the camera socket.
      • Apply a little force on the top of the camera to slide it in the socket.
      • Pop the camera in the socket and make sure its stable.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Shantanu Malhotra
178 Reputatie
1 Handleiding geschreven
USF Tampa, Team S2-G5, Eyestone Spring 2018 Lid van USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 550
