Ga door naar hoofdinhoud
BLU Life X8 Front Camera Replacement
Wat je nodig hebt
  1. BLU Life X8 Front Camera Replacement, Battery: stap 1, afbeelding 1 van 2 BLU Life X8 Front Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
    Vraag FixBot
    Voeg opmerking toe
  2. BLU Life X8 Front Camera Replacement: stap 2, afbeelding 1 van 1
    • Use your thumb to pry off the back panel once the gap is large enough.
    Vraag FixBot
    Voeg opmerking toe
  3. BLU Life X8 Front Camera Replacement: stap 3, afbeelding 1 van 1
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
    Vraag FixBot
    Voeg opmerking toe
  4. BLU Life X8 Front Camera Replacement, Motherboard: stap 4, afbeelding 1 van 2 BLU Life X8 Front Camera Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
    Vraag FixBot
    Voeg opmerking toe
  5. BLU Life X8 Front Camera Replacement: stap 5, afbeelding 1 van 1
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from re-engaging.
    Vraag FixBot
    Voeg opmerking toe
  6. BLU Life X8 Front Camera Replacement: stap 6, afbeelding 1 van 1
    • Once all the clips have been released, lift the frame and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  7. BLU Life X8 Front Camera Replacement: stap 7, afbeelding 1 van 2 BLU Life X8 Front Camera Replacement: stap 7, afbeelding 2 van 2
    • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. BLU Life X8 Front Camera Replacement: stap 8, afbeelding 1 van 3 BLU Life X8 Front Camera Replacement: stap 8, afbeelding 2 van 3 BLU Life X8 Front Camera Replacement: stap 8, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
    • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
    Vraag FixBot
    Voeg opmerking toe
  9. BLU Life X8 Front Camera Replacement: stap 9, afbeelding 1 van 1
    • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
    Vraag FixBot
    Voeg opmerking toe
  10. BLU Life X8 Front Camera Replacement: stap 10, afbeelding 1 van 1
    • Slowly lift the vibration motor away from the frame and peel up the tape.
    Vraag FixBot
    Voeg opmerking toe
  11. BLU Life X8 Front Camera Replacement, Front Camera: stap 11, afbeelding 1 van 1
    • Flip the motherboard over.
    • Lift the front camera from its housing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Alexander Prasil
555 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G2, Nance Fall 2017 Lid van USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 453
