Ga door naar hoofdinhoud
BLU Life X8 Back Camera Replacement
Wat je nodig hebt
  1. BLU Life X8 Back Camera Replacement, Battery: stap 1, afbeelding 1 van 2 BLU Life X8 Back Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
    Vraag FixBot
    Voeg opmerking toe
  2. BLU Life X8 Back Camera Replacement: stap 2, afbeelding 1 van 1
    • Use your thumb to pry off the back panel once the gap is large enough.
    Vraag FixBot
    Voeg opmerking toe
  3. BLU Life X8 Back Camera Replacement: stap 3, afbeelding 1 van 1
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
    Vraag FixBot
    Voeg opmerking toe
  4. BLU Life X8 Back Camera Replacement, Back Camera: stap 4, afbeelding 1 van 2 BLU Life X8 Back Camera Replacement, Back Camera: stap 4, afbeelding 2 van 2
    • Use the Phillips #00 (1.5mm) bit to undo the (9) screws from the back of the device.
    Vraag FixBot
    Voeg opmerking toe
  5. BLU Life X8 Back Camera Replacement: stap 5, afbeelding 1 van 1
    • Wedge the opening tool into the seam of between the screen and the gray frame.
    • Run the opening tool along the seam to release the clips that hold the two pieces together.
    • You may need to use the opening picks to prevent the clips from reengaging.
    Vraag FixBot
    Voeg opmerking toe
  6. BLU Life X8 Back Camera Replacement: stap 6, afbeelding 1 van 1
    • Once all the clips have been released, pull back the frame and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  7. BLU Life X8 Back Camera Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use the tweezers to unlock the ribbon cable from the motherboard
    • The ribbon cable should be free. Pull back on the ribbons to release it from the connector
    Vraag FixBot
    Voeg opmerking toe
  8. BLU Life X8 Back Camera Replacement: stap 8, afbeelding 1 van 1
    • Lift the back camera from its housing
    • The back camera may be glued to the phone
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexander Prasil
555 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G2, Nance Fall 2017 Lid van USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 548
