Ga door naar hoofdinhoud
Azpen A740 Speaker Replacement
Wat je nodig hebt
  1. Azpen A740 Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Speaker Replacement, Speaker: stap 2, afbeelding 1 van 2 Azpen A740 Speaker Replacement, Speaker: stap 2, afbeelding 2 van 2
    • The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver.
  3. Azpen A740 Speaker Replacement: stap 3, afbeelding 1 van 2 Azpen A740 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Once the screws are removed, you should fully desolder the speaker wires that are attached to the motherboard. Instructions on how to desolder these wires are here on ifixit: Hoe moet je (de-)solderen?
    • After switching out the old speaker, just follow the directions in reverse to finish.
Conclusie
Mallory
346 Reputatie
3 handleidingen geschreven
USF Tampa, Team 4-5, Brown Winter 2015 Lid van USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 115
