Ga door naar hoofdinhoud
Azpen A720 Speaker Replacement
Wat je nodig hebt
  1. Azpen A720 Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 2 Azpen A720 Speaker Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Speaker Replacement: stap 2, afbeelding 1 van 3 Azpen A720 Speaker Replacement: stap 2, afbeelding 2 van 3 Azpen A720 Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the rear casing.
  4. Azpen A720 Speaker Replacement, Speaker: stap 4, afbeelding 1 van 1
    • The speaker is a black oval located in the corner next to the battery.
  5. Azpen A720 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
    • Remember which lead the black and red wires connect to on the motherboard.
    • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
  6. Azpen A720 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the speaker from the tablet.
Conclusie
Anna
353 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 1-3, Lauer Spring 2015 Lid van Michigan Tech, Team 1-3, Lauer Spring 2015
MTU-LAUER-S15S1G3
2 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 245
