Ga door naar hoofdinhoud
Azpen A701 Motherboard Replacement
Wat je nodig hebt
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: stap 1, afbeelding 1 van 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: stap 2, afbeelding 1 van 2 Azpen A701 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 Azpen A701 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 Azpen A701 Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: stap 6, afbeelding 1 van 3 Azpen A701 Motherboard Replacement: stap 6, afbeelding 2 van 3 Azpen A701 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
Conclusie
Michael
568 Reputatie
4 handleidingen geschreven
Colorado Springs, Team 2-1, Panko Spring 2015 Lid van Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 328
