Inleiding
The battery in the A701 is located adjacent to the motherboard (the blue L-shaped piece) and has soldered wires. Before continuing, be sure you have all the necessary tools and safety equipment.
A guide to soldering can be found here.
Wat je nodig hebt
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
