Ga door naar hoofdinhoud
Azpen A701 Battery Replacement
Wat je nodig hebt
  1. Azpen A701 Battery Replacement, General Disassembly Prerequisite Guide: stap 1, afbeelding 1 van 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Battery Replacement: stap 2, afbeelding 1 van 2 Azpen A701 Battery Replacement: stap 2, afbeelding 2 van 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Battery Replacement: stap 3, afbeelding 1 van 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
    • For more information on soldering, please refer to iFixit's guide here.
  6. Azpen A701 Battery Replacement: stap 6, afbeelding 1 van 1
    • Insert new battery by soldering red and black wires onto the motherboard.
    • Make sure to solder the wires back on in the correct configuration (as pictured).
Conclusie
Grant Harding
249 Reputatie
2 handleidingen geschreven
Colorado Springs, Team 2-1, Panko Spring 2015 Lid van Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 718
