Ga door naar hoofdinhoud
Axess TA2513-10WT Battery Replacement
Wat je nodig hebt
    1. Axess TA2513-10WT Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
      • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
      Vraag FixBot
      Voeg opmerking toe
    2. Axess TA2513-10WT Battery Replacement: stap 2, afbeelding 1 van 3 Axess TA2513-10WT Battery Replacement: stap 2, afbeelding 2 van 3 Axess TA2513-10WT Battery Replacement: stap 2, afbeelding 3 van 3
      • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
      • Slide the plastic opening tool gently along the sides.
      • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
      Vraag FixBot
      Voeg opmerking toe
    3. Axess TA2513-10WT Battery Replacement: stap 3, afbeelding 1 van 1
      • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
      Vraag FixBot
      Voeg opmerking toe
    4. Axess TA2513-10WT Battery Replacement: stap 4, afbeelding 1 van 1
      • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
      Vraag FixBot
      Voeg opmerking toe
    1. Axess TA2513-10WT Battery Replacement, Battery: stap 5, afbeelding 1 van 1
      • Shove the Spudger below the battery pack to remove any tape or adhesive residue.
      Vraag FixBot
      Voeg opmerking toe
    2. Axess TA2513-10WT Battery Replacement: stap 6, afbeelding 1 van 1
      • Lift the battery up with your hands to ensure complete detachment from the screen.
      Vraag FixBot
      Voeg opmerking toe
    3. Axess TA2513-10WT Battery Replacement: stap 7, afbeelding 1 van 1
      • Identify the red wire attached to the node labeled "B+" and the black wire attached to the node labeled "B-"
      Vraag FixBot
      Voeg opmerking toe
    4. Axess TA2513-10WT Battery Replacement: stap 8, afbeelding 1 van 1
      • Press the heated soldering iron down on the "B+" node while simultaneously tugging on the red wire.
      Vraag FixBot
      Voeg opmerking toe
    5. Axess TA2513-10WT Battery Replacement: stap 9, afbeelding 1 van 1
      • Remove the red wire from the node labeled "B+"
      Vraag FixBot
      Voeg opmerking toe
    6. Axess TA2513-10WT Battery Replacement: stap 10, afbeelding 1 van 1
      • Using the same process as the red wire, detach the black wire from the node labeled "B-".
      Vraag FixBot
      Voeg opmerking toe
    7. Axess TA2513-10WT Battery Replacement: stap 11, afbeelding 1 van 1
      • The battery should now be separated from both the screen and circuit board
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Steven Kavanagh
301 Reputatie
3 handleidingen geschreven
Baylor, Team 6-3, Shaver Spring 2015 Lid van Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 669
