Ga door naar hoofdinhoud
Auking M8-F PCB Button Panel Replacement
Wat je nodig hebt
  1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: stap 1, afbeelding 1 van 2 Auking M8-F PCB Button Panel Replacement, PCB Button Panel: stap 1, afbeelding 2 van 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. Auking M8-F PCB Button Panel Replacement: stap 2, afbeelding 1 van 2 Auking M8-F PCB Button Panel Replacement: stap 2, afbeelding 2 van 2
    • Carefully prop open the top of the projector.
    • Disconnect the cable attached to the top lid.
    • Remove the top lid.
  3. Auking M8-F PCB Button Panel Replacement: stap 3, afbeelding 1 van 2 Auking M8-F PCB Button Panel Replacement: stap 3, afbeelding 2 van 2
    • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
  4. Auking M8-F PCB Button Panel Replacement: stap 4, afbeelding 1 van 3 Auking M8-F PCB Button Panel Replacement: stap 4, afbeelding 2 van 3 Auking M8-F PCB Button Panel Replacement: stap 4, afbeelding 3 van 3
    • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
    • Remove the power panel.
Conclusie
Aubrey Haynes
286 Reputatie
3 handleidingen geschreven
1Gids Commentaar
I have a problem not covered here.
When I power up, only a red light is lit. Any ideas?
sasquachnw@duck.com
sasquachnw - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 210
