Ga door naar hoofdinhoud
Aukey KM-G9 87 key mechanical keyboard Disassembly
Wat je nodig hebt
  1. Aukey KM-G9 87 key mechanical keyboard Disassembly, Overview: stap 1, afbeelding 1 van 3 Aukey KM-G9 87 key mechanical keyboard Disassembly, Overview: stap 1, afbeelding 2 van 3 Aukey KM-G9 87 key mechanical keyboard Disassembly, Overview: stap 1, afbeelding 3 van 3
    • The keyboard as it appears before doing any disassembly.
  2. Aukey KM-G9 87 key mechanical keyboard Disassembly, Remove keycaps.: stap 2, afbeelding 1 van 1
    • Remove the keycaps by gently pulling them straight upwards.
  3. Aukey KM-G9 87 key mechanical keyboard Disassembly, Remove screws: stap 3, afbeelding 1 van 1
    • There are 12 screws located between the keys (marked with orange circles on the photograph). Remove them with a Phillips PH1 screwdriver.
  4. Aukey KM-G9 87 key mechanical keyboard Disassembly, Remove the backplate and see the internals: stap 4, afbeelding 1 van 3 Aukey KM-G9 87 key mechanical keyboard Disassembly, Remove the backplate and see the internals: stap 4, afbeelding 2 van 3 Aukey KM-G9 87 key mechanical keyboard Disassembly, Remove the backplate and see the internals: stap 4, afbeelding 3 van 3
    • Now the backplate can easily be removed.
    • The backside of the PCB and the controller board can be seen. The USB-cable is attached via a connector, use a flat screwdriver to carefully push it out (don't pull on the cable since that might break it).
    • The PCB is hard to remove (don't know if it is possible at all without destruction), since it is hold by the switches which are soldered to the PCB, and on the other side the switches are hold by the frontplate.
    • To reassemble your device, follow these instructions in reverse order.
Eindstreep
Drei Eck
160 Reputatie
1 Handleiding geschreven
2Gids Commentaar
Are the keys themselves removable if you were to try to replace them with different color keys?
Ricardo Martinez - Antwoord
When you unsolder the old ones, yes. They are soldered. So no easy replacement.
Drei Eck -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 1,227
