Ga door naar hoofdinhoud
August Smart Lock Speaker Replacement
Wat je nodig hebt
  1. August Smart Lock Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 August Smart Lock Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 August Smart Lock Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Flip the device so the back cover is facing you.
    • Undo the latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  2. August Smart Lock Speaker Replacement: stap 2, afbeelding 1 van 3 August Smart Lock Speaker Replacement: stap 2, afbeelding 2 van 3 August Smart Lock Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use the metal spudger to pry the plug off of the motherboard.
    • The plug can be dislodged when prying it from the side.
    Vraag FixBot
    Voeg opmerking toe
  3. August Smart Lock Speaker Replacement: stap 3, afbeelding 1 van 3 August Smart Lock Speaker Replacement: stap 3, afbeelding 2 van 3 August Smart Lock Speaker Replacement: stap 3, afbeelding 3 van 3
    • Warm up the iOpener.
    • Do not place the iOpener in microwave for more than 30 seconds.
    • Place the iOpener heating pad over the speaker and let sit for a few moments.
    • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
    Vraag FixBot
    Voeg opmerking toe
  4. August Smart Lock Speaker Replacement: stap 4, afbeelding 1 van 2 August Smart Lock Speaker Replacement: stap 4, afbeelding 2 van 2
    • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
William Fink
841 Reputatie
3 handleidingen geschreven
USF Tampa, Team S11-G6, Passmore Fall 2017 Lid van USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 1,898
