Ga door naar hoofdinhoud
August Smart Lock Gear Replacement
Wat je nodig hebt
  1. August Smart Lock Gear Replacement, Gear: stap 1, afbeelding 1 van 3 August Smart Lock Gear Replacement, Gear: stap 1, afbeelding 2 van 3 August Smart Lock Gear Replacement, Gear: stap 1, afbeelding 3 van 3
    • Flip the device over so the metal plate is facing you.
    • Undo the latches on the side to remove the metal plate.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  2. August Smart Lock Gear Replacement: stap 2, afbeelding 1 van 3 August Smart Lock Gear Replacement: stap 2, afbeelding 2 van 3 August Smart Lock Gear Replacement: stap 2, afbeelding 3 van 3
    • Lift the cover off the device and set to the side.
    • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
    • Remove the gears as shown.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
12 andere personen hebben deze handleiding voltooid.
William Fink
841 Reputatie
3 handleidingen geschreven
USF Tampa, Team S11-G6, Passmore Fall 2017 Lid van USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Leden
6 handleidingen geschreven
8Gids Commentaar
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - Antwoord Deel
Any tips on where to get replacement gears?
Byron H - Antwoord Deel
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - Antwoord Deel
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante - Antwoord Deel
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 66
Altijd: 14,040
