Ga door naar hoofdinhoud
August Smart Lock Accelerometer Replacement
Wat je nodig hebt
  1. August Smart Lock Accelerometer Replacement, Accelerometer: stap 1, afbeelding 1 van 3 August Smart Lock Accelerometer Replacement, Accelerometer: stap 1, afbeelding 2 van 3 August Smart Lock Accelerometer Replacement, Accelerometer: stap 1, afbeelding 3 van 3
    • Flip device over so the black bottom is facing you.
    • Undo latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  2. August Smart Lock Accelerometer Replacement: stap 2, afbeelding 1 van 3 August Smart Lock Accelerometer Replacement: stap 2, afbeelding 2 van 3 August Smart Lock Accelerometer Replacement: stap 2, afbeelding 3 van 3
    • Grab the gears and lift them up to remove from the device
    Vraag FixBot
    Voeg opmerking toe
  3. August Smart Lock Accelerometer Replacement: stap 3, afbeelding 1 van 3 August Smart Lock Accelerometer Replacement: stap 3, afbeelding 2 van 3 August Smart Lock Accelerometer Replacement: stap 3, afbeelding 3 van 3
    • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
    • Disconnect the speaker plug from the motherboard
    • Disconnect the battery plugs from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. August Smart Lock Accelerometer Replacement: stap 4, afbeelding 1 van 1
    • Once the speaker is disconnected, remove the back cover.
    • Lift up the motherboard and motor assembly out of the device.
    Vraag FixBot
    Voeg opmerking toe
  5. August Smart Lock Accelerometer Replacement: stap 5, afbeelding 1 van 2 August Smart Lock Accelerometer Replacement: stap 5, afbeelding 2 van 2
    • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
    • Lift up the black tab to remove the ribbon from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
William Fink
841 Reputatie
3 handleidingen geschreven
USF Tampa, Team S11-G6, Passmore Fall 2017 Lid van USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Leden
6 handleidingen geschreven
7Gids Commentaar
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Antwoord Deel
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Antwoord Deel
Same as above…. where to locate an accelerometer??
osallabe - Antwoord Deel
Did anyone find out where to buy the part?
LBurd - Antwoord Deel
Where can I find one
Jeff Wasilewski - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 60
Altijd: 8,855
