Ga door naar hoofdinhoud
Audiovox Tri-mode CDM-9000 Keypad Replacement
Wat je nodig hebt
    1. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: stap 1, afbeelding 1 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: stap 1, afbeelding 2 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: stap 1, afbeelding 3 van 3
      • Flip your phone over so the screen is facing down.
      • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
      Vraag FixBot
      Voeg opmerking toe
    2. Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 2, afbeelding 1 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 2, afbeelding 2 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 2, afbeelding 3 van 3
      • Once the battery has been removed, you will need a small Phillips 60 mm screwdriver. Remove the two 1.2mm Phillips #1 screws on the back of the phone.
      • Use a spudger tool to pry apart the phone. It may be a little difficult to pry open. Use the flat part of the spudger tool and go all around the phone. It will come apart.
      Vraag FixBot
      Voeg opmerking toe
    3. Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 3, afbeelding 1 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 3, afbeelding 2 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 3, afbeelding 3 van 3
      • Once you have the phone apart simply remove the key pad and replace it with the new one.
      • Don't forget to put the screws back in. Place the battery back on the phone.
      • Push the two parts of the phone back together. You will here a loud click when the phone is back together.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Summer Sines
406 Reputatie
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 543
