Inleiding
If the power adapter isn't working, install a new one! This guide shows you how to change out an old power adapter that may not be working right.
Note: This guide involves soldering and should not be done by children. If you do not know how to solder, check out How To Solder and Desolder Connections to learn how before beginning this guide.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Begin by applying constant pressure to the base of your Audiovox while holding the plastic casing. Do this until the plastic casing is completely removed.
One by one, de-solder the two wires that connect the power adapter to your Audiovox.
