Ga door naar hoofdinhoud
Audiovox CR8030iE5 Docking Port Replacement
Wat je nodig hebt
  1. Audiovox CR8030iE5 Docking Port Replacement, Top-Casing: stap 1, afbeelding 1 van 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Docking Port Replacement: stap 2, afbeelding 1 van 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Docking Port Replacement: stap 3, afbeelding 1 van 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Docking Port Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Docking Port Replacement: stap 5, afbeelding 1 van 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Docking Port Replacement, Docking Port: stap 6, afbeelding 1 van 1
    • One by one, de-solder the line of nine wires attached to the docking port board. After pulling out the wires, save them. This is done so that you can solder them into the new docking port board.
    • If you don't know how to solder, check out Hoe moet je (de-)solderen?.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  7. Audiovox CR8030iE5 Docking Port Replacement: stap 7, afbeelding 1 van 1
    • Carefully insert the wires into the designated holes on the new docking port board and solder them into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nab Sengupta
55 Reputatie
4 handleidingen geschreven
Cal Poly, Team 10-39, Amido Spring 2013 Lid van Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 372
