Ga door naar hoofdinhoud
Audiovox CR8030iE5 Backlight Replacement
Wat je nodig hebt
  1. Audiovox CR8030iE5 Backlight Replacement, Top-Casing: stap 1, afbeelding 1 van 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Backlight Replacement: stap 2, afbeelding 1 van 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Backlight Replacement: stap 3, afbeelding 1 van 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Backlight Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Backlight Replacement: stap 5, afbeelding 1 van 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Backlight Replacement, Backlight: stap 6, afbeelding 1 van 1
    • Insert a Phillips #1 screwdriver into the corner, square, holes and push the backlight board up away from the plastic casing.
  7. Audiovox CR8030iE5 Backlight Replacement: stap 7, afbeelding 1 van 1
    • Carefully, pull up on the board to remove it entirely from the plastic casing.
  8. Audiovox CR8030iE5 Backlight Replacement: stap 8, afbeelding 1 van 1
    • Flip the backlight board over to view the underside.
  9. Audiovox CR8030iE5 Backlight Replacement: stap 9, afbeelding 1 van 1
    • One by one, de-solder the four wires (two wires corresponding to each LED bulb) that attach the backlight to the board.
    • If you don't know how to solder, check out Hoe moet je (de-)solderen?.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  10. Audiovox CR8030iE5 Backlight Replacement: stap 10, afbeelding 1 van 1
    • Remove the two LED light bulbs.
    • Insert each wire from the new LED bulbs into the respective holes.
  11. Audiovox CR8030iE5 Backlight Replacement: stap 11, afbeelding 1 van 1
    • One by one, solder the backlight wires back into place.
Conclusie
Nab Sengupta
55 Reputatie
4 handleidingen geschreven
Cal Poly, Team 10-39, Amido Spring 2013 Lid van Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 330
