Ga door naar hoofdinhoud
Audiovox CDM-8910 Keyboard Replacement
Wat je nodig hebt
  1. Audiovox CDM-8910 Keyboard Replacement, Antenna: stap 1, afbeelding 1 van 1
    • Locate the antenna (shown in red box) at the top of the phone when closed.
    Vraag FixBot
    Voeg opmerking toe
  2. Audiovox CDM-8910 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
    Vraag FixBot
    Voeg opmerking toe
  3. Audiovox CDM-8910 Keyboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
    Vraag FixBot
    Voeg opmerking toe
  4. Audiovox CDM-8910 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
    Vraag FixBot
    Voeg opmerking toe
  5. Audiovox CDM-8910 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • The back of the phone will look like this when the battery is correctly removed.
    Vraag FixBot
    Voeg opmerking toe
  6. Audiovox CDM-8910 Keyboard Replacement, Rear Case: stap 6, afbeelding 1 van 1
    • Peel the rubber indicated toward the top of the phone
    Vraag FixBot
    Voeg opmerking toe
  7. Audiovox CDM-8910 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the screw that sits underneath the rubber covering.
    Vraag FixBot
    Voeg opmerking toe
  8. Audiovox CDM-8910 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the five (5) total screws using a Philips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  9. Audiovox CDM-8910 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
    Vraag FixBot
    Voeg opmerking toe
  10. Audiovox CDM-8910 Keyboard Replacement: stap 10, afbeelding 1 van 1
    • The back case should now be completely removed and the motherboard will be visible.
    Vraag FixBot
    Voeg opmerking toe
  11. Audiovox CDM-8910 Keyboard Replacement, Motherboard: stap 11, afbeelding 1 van 3 Audiovox CDM-8910 Keyboard Replacement, Motherboard: stap 11, afbeelding 2 van 3 Audiovox CDM-8910 Keyboard Replacement, Motherboard: stap 11, afbeelding 3 van 3
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
    Vraag FixBot
    Voeg opmerking toe
  12. Audiovox CDM-8910 Keyboard Replacement: stap 12, afbeelding 1 van 1
    • Using a spudger, lift the motherboard out of the phone case as pictured.
    Vraag FixBot
    Voeg opmerking toe
  13. Audiovox CDM-8910 Keyboard Replacement: stap 13, afbeelding 1 van 1
    • The motherboard should now be completely removed from the phone.
    Vraag FixBot
    Voeg opmerking toe
  14. Audiovox CDM-8910 Keyboard Replacement, Keyboard: stap 14, afbeelding 1 van 1
    • Once the motherboard has been removed, peel the keyboard as pictured.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Carlos Guerrero
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-24, Regan Fall 2010 Lid van Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 27
Altijd: 1,782
