Ga door naar hoofdinhoud
Audio-Technica AT-LP120XUSB Velocity PCB Replacement
Wat je nodig hebt
    1. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: stap 1, afbeelding 1 van 3 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: stap 1, afbeelding 2 van 3 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Prepare Turntable: stap 1, afbeelding 3 van 3
      • Disconnect any cables from the rear of the turntable and move it to a clear surface.
      • With the turntable facing you, remove the following accessories and tie down the tonearm:
      • Dust Cover & Hinges
      • Black felt mat
      • Platter
      • Headshell & Counterweight
      • 45 Adapter
      • Any other loose accessories that may be on the surface of the turntable should be removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Removing Bottom Cover: stap 2, afbeelding 1 van 1
      • Before flipping the turntable upside-down, get a large soft object (ex. pillow, blanket, etc...) to minimize the possibility of damage.
      • Using a #PH1 Screwdriver, remove the 13 screws marked
      • Using a #PH0 Screwdriver, remove the 2 screws marked.
      Vraag FixBot
      Voeg opmerking toe
    3. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: stap 3, afbeelding 1 van 3 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: stap 3, afbeelding 2 van 3 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Velocity PCB Location and Removal: stap 3, afbeelding 3 van 3
      • With the bottom panel removed, locate the Velocity PCB.
      • Locate the 3 connectors, and remove them from their corresponding PCBs.
      • Using a #PH0 screwdriver, remove these 6 screws.
      • After the screws are removed and connectors are loose, the Velocity PCB can be removed.
      Vraag FixBot
      Voeg opmerking toe
    4. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: stap 4, afbeelding 1 van 3 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: stap 4, afbeelding 2 van 3 Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Replacing Velocity PCB: stap 4, afbeelding 3 van 3
      • Before mounting the 6 screws, plug in the short connector to the Velocity PCB.
      • Mount the Velocity PCB using the guide post, and secure it with the 6 screws.
      • Connect the 2 longer leads to their corresponding PCBs.
      Vraag FixBot
      Voeg opmerking toe
    5. Audio-Technica AT-LP120XUSB Velocity PCB Replacement, Reassembly: stap 5, afbeelding 1 van 1
      • Place the bottom cover back on.
      • Using a #PH1 Screwdriver, secure the bottom cover with the 13 longer screws.
      • Using a #PH0 Screwdriver, secure the bottom cover with the 2 shorter screws.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Once the repair is completed, put all of your accessories back onto the turntable and reconnect any cables you were using.
For assistance balancing your tonearm, follow the guide attached below.
Bijgevoegde documenten
ATUS Service Dept
764 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 75
Altijd: 676
