Inleiding
This guide will help your install a new driver.
Wat je nodig hebt
With a #0 phillips head, unscrew the three, 1 cm screws which are holding the driver (red wafer) in its bracket.
Remove the two wires, red and yellow, by de-soldering them from the driver using a soldering iron and desoldering wick. Reference Hoe moet je (de-)solderen?.
2 opmerkingen
where can i buy a replacement driver?
You can order parts directly from PARTS@ATUS.COM
