Ga door naar hoofdinhoud
Atmega328P Microcontroller Replacement for Arduino Board
Wat je nodig hebt
  1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: stap 1, afbeelding 1 van 1
    • Place the Arduino UNO R3 board on a flat clean surface.
    Vraag FixBot
    Voeg opmerking toe
  2. Atmega328P Microcontroller Replacement for Arduino Board: stap 2, afbeelding 1 van 2 Atmega328P Microcontroller Replacement for Arduino Board: stap 2, afbeelding 2 van 2
    • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
    • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
    Vraag FixBot
    Voeg opmerking toe
  3. Atmega328P Microcontroller Replacement for Arduino Board: stap 3, afbeelding 1 van 2 Atmega328P Microcontroller Replacement for Arduino Board: stap 3, afbeelding 2 van 2
    • Repeat the same process on the other side.
    • Lift both sides evenly to prevent any damage to the pins.
    Vraag FixBot
    Voeg opmerking toe
  4. Atmega328P Microcontroller Replacement for Arduino Board: stap 4, afbeelding 1 van 3 Atmega328P Microcontroller Replacement for Arduino Board: stap 4, afbeelding 2 van 3 Atmega328P Microcontroller Replacement for Arduino Board: stap 4, afbeelding 3 van 3
    • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
    Vraag FixBot
    Voeg opmerking toe
  5. Atmega328P Microcontroller Replacement for Arduino Board: stap 5, afbeelding 1 van 1
    • Remove replacement microcontroller out of packaging.
    Vraag FixBot
    Voeg opmerking toe
  6. Atmega328P Microcontroller Replacement for Arduino Board: stap 6, afbeelding 1 van 1
    • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
    • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
    Vraag FixBot
    Voeg opmerking toe
  7. Atmega328P Microcontroller Replacement for Arduino Board: stap 7, afbeelding 1 van 2 Atmega328P Microcontroller Replacement for Arduino Board: stap 7, afbeelding 2 van 2
    • Gently press the microcontroller into the dip socket
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Youssef Qteshat
217 Reputatie
1 Handleiding geschreven
UC Davis, Team 5-5, Morris Winter 2023 Lid van UC Davis, Team 5-5, Morris Winter 2023
UCD-MORRIS-W23S5G5
2 Leden
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 61
Altijd: 1,397
