Ga door naar hoofdinhoud
Atari Lynx Backlight Replacement
Wat je nodig hebt
  1. Atari Lynx Backlight Replacement, Atari Lynx: stap 1, afbeelding 1 van 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Backlight Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Backlight Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Backlight Replacement: stap 4, afbeelding 1 van 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Backlight Replacement, Backlight: stap 5, afbeelding 1 van 1
    • Pull out the logic-board.
    • Pull to the sides the four rubber tabs holding in the screen
  6. Atari Lynx Backlight Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the two 10 mm screws as shown with a Phillips #0 screwdriver in order to remove the shield behind the backlight.
  7. Atari Lynx Backlight Replacement: stap 7, afbeelding 1 van 1
    • Flip over the motherboard and remove the shield behind the backlight.
  8. Atari Lynx Backlight Replacement: stap 8, afbeelding 1 van 2 Atari Lynx Backlight Replacement: stap 8, afbeelding 2 van 2
    • Flip the motherboard back over and desolder the two components that are holding the backlight in place.
    • If you need help with basic desoldering, click here.
Conclusie
4 andere personen hebben deze handleiding voltooid.
John Lopez
446 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-42, Maness Winter 2014 Lid van Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Leden
16 handleidingen geschreven
1Gids Commentaar
Good instructions but my Atari is different
909 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 35
Altijd: 5,060
