Inleiding
If the joystick on an Atari Flashback 2 controller is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the controller in order to access the joystick efficiently.
Wat je nodig hebt
Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
Remove the bottom panel from the joystick.
