Ga door naar hoofdinhoud
Atari Flashback 2 Console Power Button Replacement
Wat je nodig hebt
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: stap 1, afbeelding 1 van 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: stap 1, afbeelding 2 van 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: stap 1, afbeelding 3 van 3
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
    Vraag FixBot
    Voeg opmerking toe
  2. Atari Flashback 2 Console Power Button Replacement: stap 2, afbeelding 1 van 3 Atari Flashback 2 Console Power Button Replacement: stap 2, afbeelding 2 van 3 Atari Flashback 2 Console Power Button Replacement: stap 2, afbeelding 3 van 3
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Faith Julian
205 Reputatie
2 handleidingen geschreven
Washington State, Team S1-G2, Hope Fall 2018 Lid van Washington State, Team S1-G2, Hope Fall 2018
WSU-HOPE-F18S1G2
4 Leden
11 handleidingen geschreven
1Gids Commentaar
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 61
Altijd: 1,423
