Ga door naar hoofdinhoud
Asus Zenfone 3 Max Battery Replacement
Wat je nodig hebt
  1. Asus Zenfone 3 Max Battery Replacement, Back cover: stap 1, afbeelding 1 van 2 Asus Zenfone 3 Max Battery Replacement, Back cover: stap 1, afbeelding 2 van 2
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  2. Asus Zenfone 3 Max Battery Replacement: stap 2, afbeelding 1 van 1
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  3. Asus Zenfone 3 Max Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Asus Zenfone 3 Max Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Asus Zenfone 3 Max Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  4. Asus Zenfone 3 Max Battery Replacement: stap 4, afbeelding 1 van 3 Asus Zenfone 3 Max Battery Replacement: stap 4, afbeelding 2 van 3 Asus Zenfone 3 Max Battery Replacement: stap 4, afbeelding 3 van 3
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lauren Compton
381 Reputatie
4 handleidingen geschreven
3 opmerkingen
I need to replace asus zenfone 3 max whole body lcd & what ever the requirements i want to know that it can be replaced or it is dead
Hassan Shahzad - Antwoord
Part not available on amazon & please bring your store to India, as the market is flooded with a ton of counterfeited products.
Deepank Malhotra - Antwoord
Asus Zenfone max 3, 5.5 এর ব্র্যাক সেল ও চার্জিং লজিক পাওয়া যাবে কি, জানাবেন প্লিজ
mafijur1122 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 47
Altijd: 3,213
