Inleiding
This guide will be all about how to replace the charging port on the Asus Zenbook UX31E. First we will be showing you how to take the back cover of the computer off. Then we will be covering how to move the rest of the components out of the way. These components include the speaker, battery, SSD, Fan, and the motherboard. Lastly, will be to replace the charging port so that you can charge your computer again.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Peel back the warranty sticker to reveal the screw under it.
Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
Remove the press fit connector attaching the motherboard to the screen.
Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
Flip the motherboard over so that the topside is facing up.
Use a soldering iron to heat up the four solder points surrounding the charging port.
Click here to see how to use a Soldering iron on a motherboard without a heat gun
Één andere persoon heeft deze handleiding voltooid.
