Ga door naar hoofdinhoud
Asus ZenWatch 2 Motherboard Replacement
Wat je nodig hebt
  1. Asus ZenWatch 2 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove the four 3.5mm screws using a T5 screwdriver to open the faceplate.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus ZenWatch 2 Motherboard Replacement: stap 2, afbeelding 1 van 2 Asus ZenWatch 2 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 1.8mm silver screws using the PH00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus ZenWatch 2 Motherboard Replacement: stap 3, afbeelding 1 van 2 Asus ZenWatch 2 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Slide the spudger under the gold-plated connection ribbon and lift to disconnect from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus ZenWatch 2 Motherboard Replacement: stap 4, afbeelding 1 van 2 Asus ZenWatch 2 Motherboard Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Pull up on the motherboard using tweezers to detach it from the watch.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew
335 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G1, Leahy Spring 2017 Lid van USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 Leden
10 handleidingen geschreven
6Gids Commentaar
Step 3 requires three different connectors to be removed from the mainboard. Not one. Attempting to remove the mainboard after only disconnecting the gold-plated connector can result in damaged digitizer/display cable.
s3ae - Antwoord Deel
Out of curiosity, I don’t see the battery hiding in any of the pictures. Is it glued or otherwise attached to the backplate of the watch, and since you’re focused on the mainboard, we’re not seeing it for that reason? Thanks!
MD5Hash - Antwoord Deel
Battery is actually stuck to the bottom side of the case. It looks to be pretty easy to replace. Connection is done with 4 sets of pins (at least 2 for battery)
Jean-Guy Rivard - Antwoord Deel
Where can you purchase a replacement motherboard?
Tasha Kanahele - Antwoord Deel
My zenfone wach 2 all function not showing please help me
Akhtar - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 39
Altijd: 3,104
