Ga door naar hoofdinhoud
Asus ZenBook UX303U Motherboard Fan Replacement
Wat je nodig hebt
  1. Asus ZenBook UX303U Motherboard Fan Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
    The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
    Jon Kerridge - Antwoord
  2. Asus ZenBook UX303U Motherboard Fan Replacement: stap 2, afbeelding 1 van 1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
    These screws on other models are Torx T5 or T6, not Phillips
    Dylan Warburg - Antwoord
    T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
    Gregg Stanley - Antwoord
  3. Asus ZenBook UX303U Motherboard Fan Replacement: stap 3, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement: stap 3, afbeelding 2 van 2
    • Using a plastic opening tool pry the back panel off of the laptop.
    I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
    djibe - Antwoord
  4. Asus ZenBook UX303U Motherboard Fan Replacement, Battery: stap 4, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement, Battery: stap 4, afbeelding 2 van 2
    • Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
    Skip this step on UX430U
    Styyvii - Antwoord
  5. Asus ZenBook UX303U Motherboard Fan Replacement: stap 5, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement: stap 5, afbeelding 2 van 2
    • Remove all seven 2 mm Phillips #00 screws from the battery.
  6. Asus ZenBook UX303U Motherboard Fan Replacement: stap 6, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement: stap 6, afbeelding 2 van 2
    • Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
    Skip this step on UX430U also
    Styyvii - Antwoord
  7. Asus ZenBook UX303U Motherboard Fan Replacement: stap 7, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement: stap 7, afbeelding 2 van 2
    • Lift the battery connector straight up off its socket to disconnect it from the motherboard.
    • Do not pry on the socket itself or you risk damaging the motherboard.
  8. Asus ZenBook UX303U Motherboard Fan Replacement: stap 8, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement: stap 8, afbeelding 2 van 2
    • Lift the battery and speakers up and pull out to remove.
    • Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
  9. Asus ZenBook UX303U Motherboard Fan Replacement: stap 9, afbeelding 1 van 1
    • Remove the speakers from the old battery.
    This was a bit more fiddly than expected given the speaker arms are stuck to the battery
  10. Asus ZenBook UX303U Motherboard Fan Replacement, Motherboard fan: stap 10, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement, Motherboard fan: stap 10, afbeelding 2 van 2
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  11. Asus ZenBook UX303U Motherboard Fan Replacement: stap 11, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement: stap 11, afbeelding 2 van 2
    • Remove the three 6mm Phillips #00 screws from the hinge.
    • Remove the 2mm Phillips #00 screw from the plastic housing securing the fan into place.
  12. Asus ZenBook UX303U Motherboard Fan Replacement: stap 12, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement: stap 12, afbeelding 2 van 2
    • Lift the bottom of the laptop up slightly in order to unhinge the laptop.
    • Lift the screen assembly hinge up and off of the motherboard fan.
  13. Asus ZenBook UX303U Motherboard Fan Replacement: stap 13, afbeelding 1 van 3 Asus ZenBook UX303U Motherboard Fan Replacement: stap 13, afbeelding 2 van 3 Asus ZenBook UX303U Motherboard Fan Replacement: stap 13, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, disconnect the cable connector from the motherboard fan.
  14. Asus ZenBook UX303U Motherboard Fan Replacement: stap 14, afbeelding 1 van 2 Asus ZenBook UX303U Motherboard Fan Replacement: stap 14, afbeelding 2 van 2
    • Lift the fan up and off of the white pegs that secure it into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Luis Perez
616 Reputatie
2 handleidingen geschreven
USF Tampa, Team S3-G5, Nance Spring 2018 Lid van USF Tampa, Team S3-G5, Nance Spring 2018
USFT-NANCE-S18S3G5
3 Leden
9 handleidingen geschreven
Één opmerking
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Nick Brennan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 2,184
