Ga door naar hoofdinhoud
Asus ZenBook UX303U Back Panel Replacement
Wat je nodig hebt
  1. Asus ZenBook UX303U Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
    The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
    Jon Kerridge - Antwoord
  2. Asus ZenBook UX303U Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
    These screws on other models are Torx T5 or T6, not Phillips
    Dylan Warburg - Antwoord
    T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
    Gregg Stanley - Antwoord
  3. Asus ZenBook UX303U Back Panel Replacement: stap 3, afbeelding 1 van 2 Asus ZenBook UX303U Back Panel Replacement: stap 3, afbeelding 2 van 2
    • Using a plastic opening tool pry the back panel off of the laptop.
    I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
    djibe - Antwoord
Conclusie
Luis Perez
616 Reputatie
2 handleidingen geschreven
USF Tampa, Team S3-G5, Nance Spring 2018 Lid van USF Tampa, Team S3-G5, Nance Spring 2018
USFT-NANCE-S18S3G5
3 Leden
9 handleidingen geschreven
Één opmerking
Some models may utilize Phillips #00 screws, but mine (and many others based on what I’ve now read) utilize Torx T5 screws around the edges of the panel.
Nick Brennan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 5,244
