Inleiding
Replacing the camera module in the Asus ZenBook UX21e is fairly simple. This guide requires removing the frame around the camera, unplugging, and replacing the module. Overall, this process is relatively simple and quick.
Wat je nodig hebt
Use a plastic opening tool to pry the display frame away from the screen.
Start from the top and carefully work around the frame until the camera module is exposed properly.
