Ga door naar hoofdinhoud
Asus Z54C-JS31 Optical Disc Drive Replacement
Wat je nodig hebt
    1. Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: stap 1, afbeelding 3 van 3
      • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
      • Slide the switch on the top right corner to the right.
      • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: stap 2, afbeelding 1 van 2 Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: stap 2, afbeelding 2 van 2
      • Turn the laptop to its normal position and open the display to show the keyboard.
      • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. Asus Z54C-JS31 Optical Disc Drive Replacement: stap 3, afbeelding 1 van 3 Asus Z54C-JS31 Optical Disc Drive Replacement: stap 3, afbeelding 2 van 3 Asus Z54C-JS31 Optical Disc Drive Replacement: stap 3, afbeelding 3 van 3
      • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
      Vraag FixBot
      Voeg opmerking toe
    1. Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: stap 4, afbeelding 1 van 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: stap 4, afbeelding 2 van 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: stap 4, afbeelding 3 van 3
      • Remove the 3mm screw with a Phillips #000 screwdriver.
      • Slide out the optical disc drive by pulling it away from the laptop.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Mark DeSimone
801 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S3-G1, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G1, Bailey Fall 2017
UMASSD-BAILEY-F17S3G1
2 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 281
