Ga door naar hoofdinhoud
Asus X751L Wireless Card Replacement
Wat je nodig hebt
  1. Asus X751L Wireless Card Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus X751L Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus X751L Wireless Card Replacement: stap 3, afbeelding 1 van 3 Asus X751L Wireless Card Replacement: stap 3, afbeelding 2 van 3 Asus X751L Wireless Card Replacement: stap 3, afbeelding 3 van 3
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus X751L Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 1
    • Remove the single 4.7mm PH00 screw holding the wireless card to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus X751L Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Using your fingers, lightly lift up on the black and white antenna cords.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus X751L Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • With your fingers lightly pull the wireless card out of the slot.
    • Make sure to keep the card parallel with the motherboard when removing from the slot.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Matthew Martin
217 Reputatie
1 Handleiding geschreven
USF Tampa, Team 17-2, Blackwell Spring 2017 Lid van USF Tampa, Team 17-2, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G2
4 Leden
5 handleidingen geschreven
1Gids Commentaar
I feel the existing WiFi card is not very good. Is there is better one I can get for the Asus X751L?
July 3, 2023.
cookbake2 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 42
Altijd: 2,823
