Ga door naar hoofdinhoud
Asus X551CA WiFi Card Replacement
Wat je nodig hebt
  1. Asus X551CA WiFi Card Replacement, Keyboard Plate Cover: stap 1, afbeelding 1 van 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    Vraag FixBot
    Voeg opmerking toe
  2. Asus X551CA WiFi Card Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus X551CA WiFi Card Replacement: stap 3, afbeelding 1 van 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus X551CA WiFi Card Replacement: stap 4, afbeelding 1 van 3 Asus X551CA WiFi Card Replacement: stap 4, afbeelding 2 van 3 Asus X551CA WiFi Card Replacement: stap 4, afbeelding 3 van 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus X551CA WiFi Card Replacement: stap 5, afbeelding 1 van 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus X551CA WiFi Card Replacement, WiFi Card: stap 6, afbeelding 1 van 1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus X551CA WiFi Card Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  8. Asus X551CA WiFi Card Replacement: stap 8, afbeelding 1 van 1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Josh
2.970 Reputatie
12 handleidingen geschreven
Cal Poly, Team 7-22, Regan Spring 2014 Lid van Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 10,049
