Ga door naar hoofdinhoud
Asus X551CA LCD Replacement
Wat je nodig hebt
  1. Asus X551CA LCD Replacement, Keyboard Plate Cover: stap 1, afbeelding 1 van 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    Vraag FixBot
    Voeg opmerking toe
  2. Asus X551CA LCD Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus X551CA LCD Replacement: stap 3, afbeelding 1 van 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus X551CA LCD Replacement: stap 4, afbeelding 1 van 3 Asus X551CA LCD Replacement: stap 4, afbeelding 2 van 3 Asus X551CA LCD Replacement: stap 4, afbeelding 3 van 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus X551CA LCD Replacement: stap 5, afbeelding 1 van 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus X551CA LCD Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus X551CA LCD Replacement: stap 7, afbeelding 1 van 1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
    Vraag FixBot
    Voeg opmerking toe
  8. Asus X551CA LCD Replacement: stap 8, afbeelding 1 van 1
    • Once it is free, remove the hard drive from its internal cavity.
    Vraag FixBot
    Voeg opmerking toe
  9. Asus X551CA LCD Replacement, Spacer: stap 9, afbeelding 1 van 1
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
    Vraag FixBot
    Voeg opmerking toe
  10. Asus X551CA LCD Replacement: stap 10, afbeelding 1 van 1
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  11. Asus X551CA LCD Replacement, WiFi Card: stap 11, afbeelding 1 van 1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. Asus X551CA LCD Replacement: stap 12, afbeelding 1 van 1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  13. Asus X551CA LCD Replacement: stap 13, afbeelding 1 van 1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    Vraag FixBot
    Voeg opmerking toe
  14. Asus X551CA LCD Replacement, Battery: stap 14, afbeelding 1 van 1
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
    Vraag FixBot
    Voeg opmerking toe
  15. Asus X551CA LCD Replacement, Motherboard: stap 15, afbeelding 1 van 1
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
    Vraag FixBot
    Voeg opmerking toe
  16. Asus X551CA LCD Replacement: stap 16, afbeelding 1 van 2 Asus X551CA LCD Replacement: stap 16, afbeelding 2 van 2
    • Now, locate the two wires connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  17. Asus X551CA LCD Replacement: stap 17, afbeelding 1 van 2 Asus X551CA LCD Replacement: stap 17, afbeelding 2 van 2
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
    Vraag FixBot
    Voeg opmerking toe
  18. Asus X551CA LCD Replacement: stap 18, afbeelding 1 van 2 Asus X551CA LCD Replacement: stap 18, afbeelding 2 van 2
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
    Vraag FixBot
    Voeg opmerking toe
  19. Asus X551CA LCD Replacement: stap 19, afbeelding 1 van 1
    • Remove the motherboard from the case by gently lifting it upward.
    Vraag FixBot
    Voeg opmerking toe
  20. Asus X551CA LCD Replacement, Front Display Bezel: stap 20, afbeelding 1 van 1
    • Locate both of the hinges that connect the monitor to the bottom plate cover.
    Vraag FixBot
    Voeg opmerking toe
  21. Asus X551CA LCD Replacement: stap 21, afbeelding 1 van 2 Asus X551CA LCD Replacement: stap 21, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
    Vraag FixBot
    Voeg opmerking toe
  22. Asus X551CA LCD Replacement: stap 22, afbeelding 1 van 1
    • Once the screws are removed, the monitor should easily lift away from the bottom plate cover
    Vraag FixBot
    Voeg opmerking toe
  23. Asus X551CA LCD Replacement: stap 23, afbeelding 1 van 1
    • Locate the two stickers that cover up the screws that hold the front bezel in place
    Vraag FixBot
    Voeg opmerking toe
  24. Asus X551CA LCD Replacement: stap 24, afbeelding 1 van 2 Asus X551CA LCD Replacement: stap 24, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to remove these stickers.
    • The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
    Vraag FixBot
    Voeg opmerking toe
  25. Asus X551CA LCD Replacement: stap 25, afbeelding 1 van 1
    • Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
    Vraag FixBot
    Voeg opmerking toe
  26. Asus X551CA LCD Replacement: stap 26, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
    Vraag FixBot
    Voeg opmerking toe
  27. Asus X551CA LCD Replacement: stap 27, afbeelding 1 van 2 Asus X551CA LCD Replacement: stap 27, afbeelding 2 van 2
    • Once the screws are taken out, the front bezel is ready to be removed.
    • Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
    • Gently use hands if necessary to separate the front bezel from the back.
    Vraag FixBot
    Voeg opmerking toe
  28. Asus X551CA LCD Replacement: stap 28, afbeelding 1 van 1
    • Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
    Vraag FixBot
    Voeg opmerking toe
  29. Asus X551CA LCD Replacement, LCD: stap 29, afbeelding 1 van 1
    • Locate the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
    Vraag FixBot
    Voeg opmerking toe
  30. Asus X551CA LCD Replacement: stap 30, afbeelding 1 van 2 Asus X551CA LCD Replacement: stap 30, afbeelding 2 van 2
    • Use the Philips #0 screwdriver to remove the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
    Vraag FixBot
    Voeg opmerking toe
  31. Asus X551CA LCD Replacement: stap 31, afbeelding 1 van 1
    • Once the screws are removed, lift up the LCD to expose the wire connecting the back bezel to the LCD.
    Vraag FixBot
    Voeg opmerking toe
  32. Asus X551CA LCD Replacement: stap 32, afbeelding 1 van 1
    • Gently unhook the wire from the back bezel to allow the LCD to be flipped over.
    Vraag FixBot
    Voeg opmerking toe
  33. Asus X551CA LCD Replacement: stap 33, afbeelding 1 van 1
    • Once flipped over, locate the ribbon that is connected to the back of the LCD.
    Vraag FixBot
    Voeg opmerking toe
  34. Asus X551CA LCD Replacement: stap 34, afbeelding 1 van 2 Asus X551CA LCD Replacement: stap 34, afbeelding 2 van 2
    • Gently tug on the ribbon to remove it from the LCD.
    Vraag FixBot
    Voeg opmerking toe
  35. Asus X551CA LCD Replacement: stap 35, afbeelding 1 van 1
    • Now that the ribbon has been detached from the back, carefully remove the LCD.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Josh
2.970 Reputatie
12 handleidingen geschreven
Cal Poly, Team 7-22, Regan Spring 2014 Lid van Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Leden
15 handleidingen geschreven
1Gids Commentaar
You don't need to disassemble the entire unit to get the panel out. Seems an overkill
Res Q Service - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 39
Altijd: 11,341
