Ga door naar hoofdinhoud
Asus X551CA Fan Replacement
Wat je nodig hebt
  1. Asus X551CA Fan Replacement, Keyboard Plate Cover: stap 1, afbeelding 1 van 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
    Vraag FixBot
    Voeg opmerking toe
  2. Asus X551CA Fan Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus X551CA Fan Replacement: stap 3, afbeelding 1 van 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus X551CA Fan Replacement: stap 4, afbeelding 1 van 3 Asus X551CA Fan Replacement: stap 4, afbeelding 2 van 3 Asus X551CA Fan Replacement: stap 4, afbeelding 3 van 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus X551CA Fan Replacement: stap 5, afbeelding 1 van 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus X551CA Fan Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus X551CA Fan Replacement: stap 7, afbeelding 1 van 1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
    Vraag FixBot
    Voeg opmerking toe
  8. Asus X551CA Fan Replacement: stap 8, afbeelding 1 van 1
    • Once it is free, remove the hard drive from its internal cavity.
    Vraag FixBot
    Voeg opmerking toe
  9. Asus X551CA Fan Replacement, Spacer: stap 9, afbeelding 1 van 1
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
    Vraag FixBot
    Voeg opmerking toe
  10. Asus X551CA Fan Replacement: stap 10, afbeelding 1 van 1
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  11. Asus X551CA Fan Replacement, WiFi Card: stap 11, afbeelding 1 van 1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. Asus X551CA Fan Replacement: stap 12, afbeelding 1 van 1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  13. Asus X551CA Fan Replacement: stap 13, afbeelding 1 van 1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
    Vraag FixBot
    Voeg opmerking toe
  14. Asus X551CA Fan Replacement, Battery: stap 14, afbeelding 1 van 1
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
    Vraag FixBot
    Voeg opmerking toe
  15. Asus X551CA Fan Replacement, Motherboard: stap 15, afbeelding 1 van 1
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
    Vraag FixBot
    Voeg opmerking toe
  16. Asus X551CA Fan Replacement: stap 16, afbeelding 1 van 2 Asus X551CA Fan Replacement: stap 16, afbeelding 2 van 2
    • Now, locate the two wires connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  17. Asus X551CA Fan Replacement: stap 17, afbeelding 1 van 2 Asus X551CA Fan Replacement: stap 17, afbeelding 2 van 2
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
    Vraag FixBot
    Voeg opmerking toe
  18. Asus X551CA Fan Replacement: stap 18, afbeelding 1 van 2 Asus X551CA Fan Replacement: stap 18, afbeelding 2 van 2
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
    Vraag FixBot
    Voeg opmerking toe
  19. Asus X551CA Fan Replacement: stap 19, afbeelding 1 van 1
    • Remove the motherboard from the case by gently lifting it upward.
    Vraag FixBot
    Voeg opmerking toe
  20. Asus X551CA Fan Replacement, Fan: stap 20, afbeelding 1 van 1
    • Once the mother board is removed, locate the fan.
    Vraag FixBot
    Voeg opmerking toe
  21. Asus X551CA Fan Replacement: stap 21, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the 5.5 mm Phillips #0 screw holding the fan in place.
    Vraag FixBot
    Voeg opmerking toe
  22. Asus X551CA Fan Replacement: stap 22, afbeelding 1 van 1
    • Lift the fan out of the laptop.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
Josh
2.970 Reputatie
12 handleidingen geschreven
Cal Poly, Team 7-22, Regan Spring 2014 Lid van Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Leden
15 handleidingen geschreven
1Gids Commentaar
Upgrade the memory while you have the motherboard out. 8GB PC3L-12800 SODIMM
iceman - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 40
Altijd: 6,191
