Ga door naar hoofdinhoud
Asus VivoBook X202E-DB21T Power Port Replacement
Wat je nodig hebt
  1. Asus VivoBook X202E-DB21T Power Port Replacement, Battery: stap 1, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Power Port Replacement: stap 2, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement: stap 2, afbeelding 2 van 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Power Port Replacement: stap 3, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement: stap 3, afbeelding 2 van 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Power Port Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Power Port Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Power Port Replacement, Hard Drive: stap 6, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement, Hard Drive: stap 6, afbeelding 2 van 2
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Power Port Replacement: stap 7, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement: stap 7, afbeelding 2 van 2
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
  8. Asus VivoBook X202E-DB21T Power Port Replacement, Motherboard: stap 8, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement, Motherboard: stap 8, afbeelding 2 van 2
    • Unscrew the five 5mm screws holding the left board together.
  9. Asus VivoBook X202E-DB21T Power Port Replacement: stap 9, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement: stap 9, afbeelding 2 van 2
    • Unplug the two connectors on the left board.
  10. Asus VivoBook X202E-DB21T Power Port Replacement: stap 10, afbeelding 1 van 3 Asus VivoBook X202E-DB21T Power Port Replacement: stap 10, afbeelding 2 van 3 Asus VivoBook X202E-DB21T Power Port Replacement: stap 10, afbeelding 3 van 3
    • Remove the single 3mm screw from the sound chip.
    • Unplug the sound chip.
    • Remove the sound chip.
  11. Asus VivoBook X202E-DB21T Power Port Replacement: stap 11, afbeelding 1 van 1
    • Remove the six 4mm screws holding the fan and CPU cover.
  12. Asus VivoBook X202E-DB21T Power Port Replacement: stap 12, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement: stap 12, afbeelding 2 van 2
    • Unplug the fan.
    • Remove the fan and CPU cover.
  13. Asus VivoBook X202E-DB21T Power Port Replacement: stap 13, afbeelding 1 van 1
    • Unscrew the nine 4mm screws holding the right board together.
  14. Asus VivoBook X202E-DB21T Power Port Replacement: stap 14, afbeelding 1 van 1
    • Remove the two remaining connectors on the board.
  15. Asus VivoBook X202E-DB21T Power Port Replacement: stap 15, afbeelding 1 van 1
    • Remove the right board.
  16. Asus VivoBook X202E-DB21T Power Port Replacement, Power Port: stap 16, afbeelding 1 van 1
    • Locate the power port on the right board near the internet port.
  17. Asus VivoBook X202E-DB21T Power Port Replacement: stap 17, afbeelding 1 van 2 Asus VivoBook X202E-DB21T Power Port Replacement: stap 17, afbeelding 2 van 2
    • De-solder the pins of the port from the board
    • See this guide on how to use a soldering iron.
    • Remove the port from the board.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 950
