Ga door naar hoofdinhoud
Asus V500CA-DB51T RAM Replacement
Wat je nodig hebt
  1. Asus V500CA-DB51T RAM Replacement, Battery: stap 1, afbeelding 1 van 2 Asus V500CA-DB51T RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • The top left and right corners have .7 cm screws.
    • The two top-middle and four bottom are .4 cm screws.
    • The middle left and right are .8 cm screws.
    • Remove the screws using the Phillips #00 screwdriver.
  2. Asus V500CA-DB51T RAM Replacement: stap 2, afbeelding 1 van 2 Asus V500CA-DB51T RAM Replacement: stap 2, afbeelding 2 van 2
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. Asus V500CA-DB51T RAM Replacement: stap 3, afbeelding 1 van 1
    • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
  4. Asus V500CA-DB51T RAM Replacement: stap 4, afbeelding 1 van 2 Asus V500CA-DB51T RAM Replacement: stap 4, afbeelding 2 van 2
    • Remove the tri-point screws that secure the battery to the casing.
    • All screws securing the battery in place are .5 cm tri-point screws.
  5. Asus V500CA-DB51T RAM Replacement: stap 5, afbeelding 1 van 3 Asus V500CA-DB51T RAM Replacement: stap 5, afbeelding 2 van 3 Asus V500CA-DB51T RAM Replacement: stap 5, afbeelding 3 van 3
    • Use the opening tool to pop up the battery away from the casing.
  6. Asus V500CA-DB51T RAM Replacement, RAM: stap 6, afbeelding 1 van 2 Asus V500CA-DB51T RAM Replacement, RAM: stap 6, afbeelding 2 van 2
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • The RAM will pop up by a few millimeters.
    • Pull the RAM stick out of its socket.
Conclusie
Galen P Garofalo
670 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S6-G2, Rockett Fall 2017 Lid van UMass Dartmouth, Team S6-G2, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G2
3 Leden
2 opmerkingen
"Step 6: Using a pair of tweezers, gently pull the RAM out of its socket." Uhhhh, NO!!!! This is horrible advice. Most tweezers are made of metal, rigid and have hard angles. #1, never touch anything metal to ANYTHING inside of a computer. You could send an electrostatic surge from your body through the tweezers to the object you're going to touch. THIS IS A GINORMOUS NO-NO!. Unless the tweezers are made of plastic or wood, you should never consider this, EVER!
The correct way to do this is to ground yourself with a grounding strap. If you don't have one of those, touch a piece of metal that may be grounded. If you don't have that, touch a computer case with both hands to drain your static charge, since computers are grounded. Then, WITH YOUR >>>HANDS ONLY<<<, remove the stick of memory.
I've been building computers for 20+ years. NEVER HAVE I EVER heard someone say use tweezers to touch any internal components. That's just a recipe for nuking your computer. DONT DO IT!
Jeff Oculush - Antwoord
Hi @jeffoculush, thank you for pointing that out! We've made an update to the guide to reflect proper instructions and also deleted the photo. Thanks again!
Sarah Westberg -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 434
