Ga door naar hoofdinhoud
Asus Transformer T100 Battery Replacement
Wat je nodig hebt
  1. Asus Transformer T100 Battery Replacement, Rear Cover: stap 1, afbeelding 1 van 2 Asus Transformer T100 Battery Replacement, Rear Cover: stap 1, afbeelding 2 van 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
    Vraag FixBot
    Voeg opmerking toe
  2. Asus Transformer T100 Battery Replacement: stap 2, afbeelding 1 van 2 Asus Transformer T100 Battery Replacement: stap 2, afbeelding 2 van 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    Vraag FixBot
    Voeg opmerking toe
  3. Asus Transformer T100 Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
    Vraag FixBot
    Voeg opmerking toe
  4. Asus Transformer T100 Battery Replacement: stap 4, afbeelding 1 van 2 Asus Transformer T100 Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the rear casing.
    Vraag FixBot
    Voeg opmerking toe
  5. Asus Transformer T100 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Remove the copper tape carefully.
    Vraag FixBot
    Voeg opmerking toe
  6. Asus Transformer T100 Battery Replacement: stap 6, afbeelding 1 van 2 Asus Transformer T100 Battery Replacement: stap 6, afbeelding 2 van 2
    • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
    Vraag FixBot
    Voeg opmerking toe
  7. Asus Transformer T100 Battery Replacement: stap 7, afbeelding 1 van 3 Asus Transformer T100 Battery Replacement: stap 7, afbeelding 2 van 3 Asus Transformer T100 Battery Replacement: stap 7, afbeelding 3 van 3
    • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
    • The battery wire harness will slide out as the battery is pried up.
    Vraag FixBot
    Voeg opmerking toe
  8. Asus Transformer T100 Battery Replacement: stap 8, afbeelding 1 van 2 Asus Transformer T100 Battery Replacement: stap 8, afbeelding 2 van 2
    • Remove the battery by slowly peeling the battery away from the connected side.
    • The adhesive on the back will pull away from the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
70 andere personen hebben deze handleiding voltooid.
Taylor Pantiga
1.629 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-31, Maness Spring 2014 Lid van Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Leden
8 handleidingen geschreven
22Gids Commentaar
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
christian cantu - Antwoord Deel
Hi christian! How did you solve this problem? That happened to me too...
Matheus Moraes - Antwoord Deel
what is the battery part # for t100 and can you purchase it?
thank you
RJ - Antwoord Deel
Part number is C12N1320. They are available from a variety of sources.
Jack Riggins - Antwoord Deel
Thanks for detailed guide.
I could not get the transformer tablet to power up no matter which buttons I held for how long or in what sequence. Unplugging the battery internally and replugging fixed a hung device.
JPWhite - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 177
Altijd: 133,320
