Inleiding
Is the camera on your Asus Transformer Pad Infinity broken? Follow this guide for instructions on how to replace the camera in your Asus Transformer Pad tablet.
Wat je nodig hebt
Insert a small flat head screwdriver into the 2 docking station guide ports on the bottom of the tablet.
Unlock screen casing tabs
Push tab with screwdriver to the right until it clicks
You should see a small arrow in the bottom of the port
Unlock the tabs in both docking station guide ports.
To remove the front facing camera (right):
Use your spudger to unlock the ribbon cable
Slide the camera out
To remove the rear facing camera (top):
Apply light lifting pressure to unplug it from it's socket
Remove the backup battery on the right side:
Unplug the cable from the motherboard with your spudger
Remove the motherboard, daughterboard, and dock connector
Unscrew 14 points
Unplug the speaker from the motherboard before removing it
Reveal the battery connector:
Flip the motherboard from the top edge of the tablet down (towards the battery).
Unplug with light pressure from your spudger.
Disconnect the motherboard from the daughterboard:
Unlock the ribbon cable on the back side of the daughterboard
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
